How hard is this to do? Will it throw sensors? What are my options to get rid of it?
I ran around for about a week with the stage 2 tune and no DPF before the ECU was reflashed for the delete. I did have a CEL which would have failed my technical inspection in Texas, and at one point the ECU decided to run a regen while I was driving which melted the reflector above my exhaust tip and left me trailing a smoke screen. Make sure you get the right software when you do the delete. The thing I like about the Malone is that it gets rid of everything, the DPF, the flapper valve, and EGR. Oil stays cleaner longer, less wear on the engine, better mileage, all that good stuff.I have the REVO software, as Toeball knows, and I'm really itching to remove my DPF and replace it with a bolt on straight pipe. I'm not too concerned about a CEL, but would prefer to see none and know that the ECU thinks everything is cool (like all right).
I'm not sure if REVO will work with me on a software upgrade that deletes the DPF, but I'm going to do my best to get them to take care of this for me.
My second option, which will be costly, will be to send my ECU to Malone and allow them to flash it.
I'm looking forward to further discussion on this topic.
Scott
http://www.myturbodiesel.com/1000q/DPF-Adblue-FAQ-VW-Audi.htmI've been under the car, during my exhaust change, and saw where there was a canister right about in the middle of the car, before a cat, and it had a wire harness attached to it. Is that the DPF?
explain where the flapper, EGR, etc... are located.
A schematic would be even better.
Check that link I posted. There are options on there to do a single high performance cat, or even a high flow DPF. With or without EGR, and the tune level you want. Pretty much what you're asking for.I would like to see an "off road" performance package that included everything need to replace all this emission stuff (dpf, flapper, at least 1 cat, etc) Like a down-pipe and enough section of exhaust to cover the rest. Along with this hardware, there should be a software flash that would safely maximize the potential of the engine with this stuff off the car, while also removing any warning lights, codes, etc...
I'm willing to pay for it, if someone will create it.
Scott
And did you have to remove any major components to get the DPF out? I think I read somewhere that the lower subframe had to be removed.These sensors are re-installed with a piece of soft line looping the two ports together on each sensor.
There are two pressure differential sensors which monitor the DPF. One sits by the gas strut that holds the hood open on an angled bracket, the other is on the firewall side of the engine. Since there is no DPF to monitor any more, and you can't leave the sensors out without causing a CEL, and leaving stuff vented to atmosphere is less than desireable, you just snip some of the original soft line which was connected to the sensor originally and make a U shaped piece across the sensor.Toeball,
Explain the sensors set up again.
Just undo the passenger side CV from the trans. Manual says the subframe needs to come out, it doesn't. You'll have to rotate the DPF as it comes out and pry up on the heat shield on the floorboard but it'll come out. I've already done two this way.And did you have to remove any major components to get the DPF out? I think I read somewhere that the lower subframe had to be removed.
It's a pain to do. It takes two guys who know what they're doing about 4 hours for the install. Part of the danger is that there are places where you must apply force and other places where you must not. As long as you take your time it's not horrible, and by the second or third one it should go fairly smoothly. I did the pulls myself both times at the exhaust shops I went to.And to be clear,
I need:
1.PDE down pipe
2.remaining exhaust to replace 2nd cat and rest of system to the rear of the car
3. software tune
Am I missing anything? and how difficult was it to install the down pipe?
I've got a great exhaust guy, but I almost think someone who knows these cars should do the work.
