Phew, okay status update. I was driving home a few days ago and noticed a distinctive hissing noise from the engine bay. It was a smooth and not too loud noise, independent of engine rpm, and seemed proportional to load on the engine and how much throttle I was giving it. Seems pretty clear that it's a boost leak. So, now I have hissing/boost leak and oil from intake tract, so I decided to pull my intake off the car to inspect and repair it. I now have the entire intake tract off the car (including the intake manifold, not including the turbo). Unfortunately, I did not perform a boost leak test before I disassembled the intake.
I found oil residue (a few drops worth) in all the intake plumbing downstream of the turbo. The intake manifold is extremely clogged with soot, and there seems to be an accumulation of oily residue at the gasket which joins the upper and lower portions of the manifold together (lower portion being the 90deg bend part that directly connects to the engine). The EGR valve is also very caked up. There was also oil leaking from interface of intake tube to EGR valve.
So, I have a couple of questions and ideas. First, since everything downstream of the turbo is oily, it seems logical that the turbo is the source of the oil. I have read that a little oil is normal, and I definitely wouldn't say that oil was pouring out of the intake tubes, again only a few drops out of each end of each tube I removed. So first question is how much oil is okay in the intake? Next question is about the boost leak. I am inclined to think that any boost leak would come from an interface between two intake pipes. Is there a way to replace or refresh these joints, or is it better to simply replace the intake tract with aftermarket parts? Is there a particular juncture that is prone to leaking? I've seen the dog collar part for the interface with the egr valve and was thinking about getting one of those.
I still haven't definitively pinpointed the source of the oil leak. My prime candidate right now is the gasket that joins the upper and lower portions of the intake manifold. I will pull it apart, clean it and replace that gasket, and hopefully that will solve that problem. If any of you have other suggestions as to the source of the oil that would be great. I haven't yet started trying to diagnose the vacuum pump or tandem pump as the source of the leak.
Wow that turned into a long one but hopefully the solution is more straightforward. Thanks!
