2008 Jetta TDI BKD , On my way to work car running well, stop at the petrol station, wont start, turn the key on, dash light light up but wont crank, check battery, thought maybe terminals loose, called friend to jumpstart but nothing, towed car home, someone tries to start the car, I listen to hear if starter clicks but nothing, pulled out the starter, 2 bolts 16mm spanner. test on the bench with Milwaukee 12v tool battery, wont spin, got to wrecking yard got a starter motor, test it there with Milwaukee 12v tool battery, spins, its fine and came home installed and car starts.
Observation: At wrecking yard looking at the amount of MK5 Jetta and Passat without starter motors tells they weren't good quality starter motors. maybe there was a TSB on starters.
