2007 Touran 1.9 TDI Electrical Problem
9.1K views 4 replies 4 participants last post by  james_hinchliffe
#1 ·
I have a Vw touran 1.9tdi 2007 model 1t2c21 with bxe engine, since last week it keeps blowing the 5amp fuse marked in in Yellow, I cant find a fuse box layout and my owners manual is not helpful.
https://drive.google.com/file/d/1G_c6fl ... sp=sharing
When this happen cluster dies completely but car still drives. After stopping and trying to start again its turns over and just dies again.
If someone has had the same problem and or a wiring diagram.
Regards
#2 · (Edited)
As I said in your PM you have made 0 posts, I should have added make an intro.
May 2004 Fuse 10 in tour picture is fuse 16
5A - Data bus diagnostic interface
-J533- Onboard supply control unit
-J519- as that picture is upside down.
May 2005 fuse 16 - 5 A Climatronic control unit -J255-
Heater/heat output switch -E16-
Control unit in dash panel insert -J285-
Oil level and oil temperature sender -G266-
Heated driver seat control unit -J131-
Heated front passenger seat control unit -
May 2006 fuse 16 - 5A
Heater/heat output switch -E16-1
Control unit in dash panel insert -J285-1
Oil level and oil temperature sender -G266-1
1 From October 2006
May 2007 fuse 16 - 5A
Fresh air blower switch -E9-
High-pressure sender -G65-
Instant heating button -E537-
Parking aid button -E266-
Automatic anti-dazzle interior mirror -Y7-
Fresh air and air recirculation flap switch - E159-
Air conditioning system control unit -J301-
Anti-dazzle interior mirror button -E386-
Heated rear window button -E230-
May 2008 fuse 16 - 5A
Power steering control unit -J500-
Fresh air blower relay -J13-
Driver door control unit -J386-
Front passenger door control unit -J387-
May 2009 fuse 16 - 5A
Air quality sensor -G238-
Fuse & Relay PDF Files
Post moved to General as we don't have a Touran sub forum even though I've asked the new admins to make one.
I also said I use ElsaWin to make all the fuse & relay layouts which you can search fleabay for.
#3 ·
Thanks again sorry, I'm from South Africa, love vw but not an mechanic or DIY freek. I appriciate the help allot. The foro is not update side, mine is a right hand drive model. That was my problem as all the information i found seem to other way around.
#5 ·
I had the same problem this week, Fuse F16 5 amp keeps blowing. I connected my multimeter to the load side of the fuse (with fuse removed) and the other probe to car earth. This measured 2 to 4 ohms (short circuit). I managed to locate the G65 (Air conditioning) high pressure sensor next to the base of the radiator. When I moved the wire, the resistance changed to over 300 K ohms. I managed to disconnect the plug from the sensor and tape it it and tuck it out of the way (Air conditioning is not working anyway). Problem solved fingers crossed!
