Hello,
I'm new on this forum. English isn't my native language, so excuse me my bad grammar.
Background information:
I'm a happy owner of VW Golf MK4 with 1.9 PD TDI engine (ATD, 101 HP, turbo with variable vanes). I had a frontal accident not so long ago with this car, and the car body was repaired, there was no need to touch the engine.
Problem:
Now the issue is that the car has a very poor fuel economy, and there is a noticeable lag in turbo boost at lower rpm, around 1800. I drive daily shorter distances ~10-15 kilometers in 5th gear within 1800-2000 rpm. No loss of power on higher rpms above 2100. The average fuel consumption was 4.5-5 l/100km, and there was no such big delay in boost.
Now the fuel consumption increased to 6.5-7.5 l/100km. I have a VCDS cable, and I did some diagnostics and logs but I still do not find the root cause and do not have idea what could be the reason.
What was checked until now:
- no failure codes of course.
- vacuum lines, check valve, EGR, N75 valve and actuator check through basic settings (tests). N75 exchanged too, but no change in behavior.
- engine timing is OK, the correction value at the PD injectors are within range.
- the turbo boost is reaching quickly the 2.1 bars in 4-5th gear with full throttle. No sign of air leak. I tried to do some minimal adjustment on the actuator rod, but it does not solve the problem. The vanes are moving smoothly.
- MAF sensor is OK. We also tried to replace it. The spec vs. actual values are close.
One thing I have noticed is that the engine ECU is reducing the duty cycle of the turbo when I accelerate, and later on the duty cycle increasing:
Is the described variation in the N75 duty cycle is nomal? I take a log from another car (1.9 TDI, ALH. 90HP), but there the cycle increasing without reduction...
Does anybody have idea what else could cause such behavior?
Did I miss something? What else could I check?
The full log is available here.
Thank you in advance for your replies.
Best Regards,
Konya
Problem:
Best Regards,
Konya
