Hi there,
I am looking for some help on my persistent engine trouble. I have a 2000 VW New Beetle GLS Tdi with a dead cylinder #4 and engine shudder along with heavy diesel smoke coming from exhaust. All cylinders seem to have fair compression and timing is correct. I presume that the cylinder is not firing because the engine noise/movement does not change while loosening injector line nut (sprays fuel) for cylinder #4 and the cylinder looks to contain unburnt diesel upon visual inspection. I swapped injection pumps and rearranged injectors but the issue still persists.
Background info:
The original engine in my car suffered a timing belt failure (February 2016) from a broken belt tensioner. The mechanic had recently replaced the timing belt assembly so I brought it back to him and he took the blame. He replaced the timing belt assembly free of charge and told me that I was lucky that everything was undamaged. One week later, the cylinder #2 lifter/follower shattered and seized the engine. I contacted the mechanic but he would not do anything about it so I bought a new engine to replace it with.
I bought a 2002 VW Jetta Auto Tdi that ran with a slight misfire and smoked at idle. The seller told me that it was a simple case of the injection timing that was causing it so I hurriedly bought it to get my car back on the road in due time. After swapping the engine (April 2016) into my Beetle, the issue still persisted after manually timing the injection pump using VCDS. I swapped the injectors from the old engine, since the nozzles had recently been replaced and calibrated with DLC 1019’s along with a tune from KermaTdi, making sure to replace the nozzle from the failed cylinder #2. Issue stayed the exact same.
I ran a compression test and got (COLD) readings of [350, 325,335,300] for cylinders [1,2,3,4]. These readings show adequate compression for the engine to run fine according to the Bentley manual so after troubleshooting further (September 2016), I decided to change the injection pump. I swapped the 11mm injection pump from the automatic, with the old 10mm pump and rearranged injectors between cylinders but #4 still was not firing and the noise/movement and exhaust stayed the same.
Any suggestions/answers to resolve my engine trouble will be greatly appreciated.
Thank you for your time,
Landon97
Background info:
Landon97
