I am looking for a TDI, willing to trade up or down for it; must be stick
HKS SSQV Blow Off Valve
APR Stage 1 ECU Upgrade: Stock Program, 93 Octane, 100 Octane (Race), Valet Program
Carbonio Carbon Fiber CAI
Oil Catch Can
OEM Hybrid Oil Pan
Eurospec Sport SIX SPEED RALLY LONG (3.94 FINAL) – 02J 6-speed Conversion
Is geared to top out at 170mph in 6th.
1st Gear – 2.7
2nd Gear – 1.8
3rd Gear – 1.45
4th Gear – 1.15
5th Gear – 0.89
6th Gear – 0.75
Final – 3.94
Quaife ATB Limited Slip
ECS Stage 1 Clutch Kit (228mm) With Light Weight Steel ECS 14lbs
EIP Lower Rear Transmission Mount
VF-Engineering Heavy Duty Engine Mounts
Center mounted steering column pod w/ VDO gauge
European Headlight Switch
GTI Monster Mats
APR 2.5†Stainless Downpipe
Euro Sport Cat-Back Exhaust 2.5" stainless steel w/Dual 3" Angle Cut Stainless Steel Tips
w/ welded in V-Band Flanges for Easy Removal
H2Sport - A4 (Mk IV) Sport Spindles
vmax coilovers
Hotchkis Sport Sway Bars (27mm front sway bar and a tubular 30mm rear sway bar)
Front Brakes: ECS OEM Big Brake Kit - (TT Carrier, 12.3 One Piece Slotted Rotor)
Rear Brakes: ECS Slotted/Cross-Drilled Rotor - 9.1â€
Brand new ball joints and lower control arms with OEM bushings
Smoked Fender mount & Bumper Side Markers
Hella Smoked Taillights
badgeless grill
4-Motion Rear Valance
Features
Heated seats
Leather
iPod/AUX
AC/Heat
Cruise Control
Sunroof
Has 90k miles on it. About 21k-22k on new transmission, gears, axels, and clutch. Only 402 approved VW oils every 3k. Loaded model with sunroof, heated seats/mirrors, black leather, gti monster mats, iPod/aux into stock headunit, cruise control, and steering controls for stereo. Could be upgraded to stage 2 right now, just like using for a daily driver as a stage 1 option, going back to stock is easy and can be done on the fly by holding the cruise control set button; generally I drive for economy in this so the tune doesn't get much use but it is a nice option.
Text (707)726-2633 with questions. Located in Barnget NJ. Or email [email protected]
Here is a link to the album: https://picasaweb.google.com/EliteGunslinger/GTI2001?feat=directlink
Extras
Including new oem oil pump w/ pickup
oil pump chain
oil tensioner
o2 sensor front and rear
valve gasket
motor mount bolts [new]
new ecs power pulley set [black]
cam chain
rear polo wiper
black vent inserts if you don't like silver
3x 5 spoke mille miglia rims [4th cracked and was thrown out]
these are all new parts I am throwing in with the car, the rims/tires are used though
Oil Catch Can
OEM Hybrid Oil Pan
1st Gear – 2.7
2nd Gear – 1.8
3rd Gear – 1.45
4th Gear – 1.15
5th Gear – 0.89
6th Gear – 0.75
Final – 3.94
GTI Monster Mats
vmax coilovers
badgeless grill
Features
Heated seats
Leather
iPod/AUX
AC/Heat
Cruise Control
Sunroof
Extras
oil pump chain
oil tensioner
valve gasket
cam chain
rear polo wiper
