1 - 8 of 8 Posts
Hi all again!
In my 1999 passat which I have just bought, I am having problems with the air for clearing the front windscreen. There are 3 buttons on the control unit which allow you to switch between air in footwells, air in face and air at windscreen. When the windscreen button is on there is very little air at the windscreen, more air at the passenger end meaning driver end takes way to long to clear. There is always air in the footwells even when they are not selected. Is this taking air away from the windscreen? or if not is this a common fault?
Thanks in advance!
Discussion Starter · #5 ·
I do have climatronic. Is it expensive to have it scanned? Also from reading on other forums, my climatronic display flashes when I turn ignition on, every symbol on display flashing until I press a button, some say this means there is a fault in it?
Hey marty, if you get stuck finding a place to do a dtc (fault code) scan for you pm me and we can organise a time & I can do it for you with VCDS. I'm also in Belfast (East). At least that way you might get a heads up to what the cause of the issue is.
May as well try to help someone keep theirs on the road seeing as my Bora is grounded atm :ugh
1 - 8 of 8 Posts
