Hi,
I have a 2002 Passat that won't start. I have only one key (it has an immo RFID chip in the fob) and had to replace the Comfort control module after it got flooded with water. I joined this forum to get some help. I have Ross Tech vag-com and was wonering if there is any process to adapt the new CCM and the original key?
Yes, there are also instructions on the ross tech website. I'm pretty sure that the CCM should be from the same type of vehicle, for example, sedan-sedan, not sedan-wagon even though they may have the same part numbers. The CCM doesn't need adaptation but I believe you need to let it know how many keys are programmed. I don't believe you need the SKC number for this because you're not adding keys. Not 100% sure on this though. Refer to the instructions.
