hi folks,
anybody know where i can find diagram of a 2005 tdi jetta? like exploded view??
my problem is that the transmission oil is leaking by the cv joints seals.. i removed the left cv joint and remarked that it is loose inside the transmission like the bearing is dead.. but it's not. when i remove the flange of the cv joint and enter my fingers in the hole in the transmission where the cv joint enters, i can lift the big part inside (differential?? ) of about 1/4'' ?? i also remarked when i flushed the oil, it was grey with inside particle when you look with a light that is bright ..
anybody have infos about that??
thanks
asterix3k
thanks
asterix3k
