21 - 26 of 26 Posts
2013 VW JSW TDI, MT
Here is the scan. Nothing related to coolant temp by my oppinion
Code:
Saturday,05,September,2020,05:26:08:40600
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN:    License Plate:
Mileage: 137750km-85593mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN:    Mileage: 137750km-85593miles
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 D    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000SG  9983
   Revision: 12H15---    Serial number:
   Coding: 0050072
   Shop #: WSC 74291 008 00000
   VCID: AF6732ED3E8354FE3A-80FA
1 Fault Found:
000257 - Mass Air Flow Sensor (G70)
               P0101 - 003 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 135868 km
                    Time Indication: 0
                    Date: 2020.06.08
                    Time: 20:11:37
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 12.08 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 1100.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
Readiness: 0 0 0 1 0
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 114B600C492800FF880D06ED92220042B70000
   Shop #: WSC 00066 000 00000
   VCID: FDFBD8A5646F766EF8-80A8
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 137017 km
                    Time Indication: 0
                    Date: 2015.01.03
                    Time: 00:21:22
             Freeze Frame:
                    Count: 2
                    Count: 1024
                    Count: 12800
                    Count: 16390
                    Count: 49152
                    Count: 0
                    Count: 260
                    Count: 0
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010002002
   Shop #: WSC 00066 000 00118
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_VW36.rod
   VCID: FBFFD6BD727B785EC6-80AE
No fault code found.
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 3068
   Revision: BG021001
   Coding: 2F380E3A802F3EC4008800C17000004449000086535D0560648020200040
   Shop #: WSC 20349 003 1048576
   VCID: B9730CB530C78A4E94-80EC
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 13021  26  0512
   Coding: 009795
5 Faults Found:
00985 - Right Tail Light (M2)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 136055 km
                    Time Indication: 0
                    Date: 2014.11.21
                    Time: 12:29:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 136055 km
                    Time Indication: 0
                    Date: 2014.11.21
                    Time: 12:29:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01504 - Bulb for License-Plate Light (X)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 17
                    Mileage: 137647 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 21:07:26
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.55 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01505 - Bulb for Blinkers; Rear Right (M8)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 136055 km
                    Time Indication: 0
                    Date: 2014.11.21
                    Time: 12:29:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01519 - Bulb for Back-Up Lights; Right (M17)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 136055 km
                    Time Indication: 0
                    Date: 2014.11.21
                    Time: 12:29:44
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R016VJQ
   Coding: 00004E42
   ASAM Dataset: EV_AirbaVW10SMEVW360 001026
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: BC7D15A137F5BF668F-80E8
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00006MPZ00
   Crash sensor for side airbag: driver side:
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME6B553349ZZZ$
   Crash sensor for side airbag: front passenger side:
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Component: S.Sens.Beif.V  H02 ----
   Serial number: 3582MSME6E271373ZZZ.
   Crash sensor for side airbag: rear: driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3511HSME385F092FZZZ
   Crash sensor for side airbag: rear: passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3521HSME0D110A2FZZZO
   Crash sensor for front airbag: driver side:
   Component: F.Sens.Fahr  --- ----
   Serial number: 35527SME145E4A2EZZZU
   Crash sensor for front airbag: front passenger side:
   Component: F.Sens.Beif  --- ----
   Serial number: 35627SME194E4A2EZZZZ
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440LLK000IA
   Coding: 108A140000
   Shop #: WSC 00066 000 00184
   ASAM Dataset: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: F2E1FB992531391695-80A6
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0046626 FLE 20130103
   Coding: 820000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5K0 920 973 C    HW: 5K0 920 973 C
   Component: KOMBI         H05 0705
   Serial number: 00000000000000
   Coding: 280F01
   Shop #: WSC 00066 123 00118
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
   VCID: B1633495E0B7420E2C-80E4
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 08011303270698
   Coding: 352002
   VCID: F4EDFD815725372687-80A0
Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RLJKS07
   Coding: 0000002
   VCID: FEF9DFA9A9696D76E1-80AA
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0705
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: EAD1E3F90DE1F1D62D-80BE
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7663940899
   Coding: 010100
   VCID: AA5123F9C56131D6ED-80FE
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0006211554
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
   VCID: DBBFB63DD2BB985EA6-808E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1509
   Serial number: 00000007513081
   Coding: 000490
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: B7770A8DC6D39C3E62-80E2
Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0006225818
   Coding: 0004B4
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
   VCID: DCBDB521D7B59F66AF-8088
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1509
   Serial number: 00000007450882
   Coding: 000490
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3407525
   Coding: 01000400040007
   VCID: E4CD8DC1E7C5A7A617-80B0
1 Fault Found:
02635 - Tuner Not Enabled/Activated
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 7
                    Fault Frequency: 4
                    Reset counter: 227
                    Mileage: 129255 km
                    Time Indication: 0
                    Date: 2019.12.26
                    Time: 02:52:51
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664011860
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: BA7113B93DC181569D-80EE
End-------------------------(Elapsed Time: 02:51)--------------------------
2013 VW JSW TDI, MT
My needle doesn't start to move from the cold position until around 110F. By 140F it parks at the 190F mark and hasn't gone any higher than that and the highest I have seen is 223F climbing out of Death Valley in June. It was the same thing with my 06 BEW. 235F seems a little high to me.
Well, 235F may see a bit high but considering conditions, i.e. towing 3000lb in 116F hot day up to a 5 miles long grade with
elevation difference about 650ft, with A/C on 2, in 5th gear (MT), around 2000rpm, 60-55mph. Starting temp was 93C (199F) gradually reaching 113C (235F) near the top of the hill. So, bit high but not surprising. I wonder how close I was to temp gauge needle to start moving. Whole point of this exercise is to find out how much "time" the temp gauge gives the driver to react/correct the situation. For example, and I'm exagerating just to make a point, it's worthless if the gauge needle does not move at all, giving a driver false comfort until it suddenly jumps to the red zone without warning. Then it can be too late to correct the situation.
The temperature gauge is a quesstimate..
I don't think I would test it by possibly overheating the engine. It would be less expensive to get another temp sensor, plug it into the harness outside the engine, and use a heat gun to answer your question.
2013 VW JSW TDI, MT
This experiment may answer my question, although little too complicated. I was hoping that the answer would be out there, already known among people who own or work on their TDIs.
So, once I know from the experiment how temp gauge behaves, related question would be at which point I should be alarmed, i.e. what is the max temp that is still safe? Based on the dash temp gauge as an ordinary driver I should not be concerned to much (just keeping an eye on it) until the needle approaches red zone, i.e. 250F. Is my assumption correct?
Does the car have any safeguards against overheating, for example shutting off A/C automatically, turning heater on, throttling fuel, eliminating post-combustion fuel injection (the one for emission reduction), etc... and some kind of alarm that you just can't ignore?
To Keithuk: Do you think I have a problem with engine? Or whith the temp gauge or both? I already posted VCDS scan in post #21 of this thread. Note that the "Engine Malfunction" occured 2000kilometers ago.
2013 VW JSW TDI, MT
Found the answer to my own question: Temp gauge needle started moving up around 115C (240F) reported by VCDS from G62-coolant temp sensor during driving. Temp gauge needle peaked the 240F mark while VCDS reported 121.5C (250F) at that moment. As the needle started raising I noticed A/C quit working. Interestingly, the 110V converter did not quit.
21 - 26 of 26 Posts
