Hey everyone, bought a 2003 Jetta ALH last month and decided to start troubleshooting the battery drain problem. I have narrowed it down to the fuse box on top of the battery. If i disconnect it from the battery the battery does not drain. There are 2 wires that have a constant voltage drop across the fuse. They are the 2nd and 3rd fuses from the left. I circled them in white. I found a wiring diagram but it was to blurry to see specifics, im starting to think the ignition cylinder. Any helps appreciated, thanks!
Edit: it is just the 2nd wire from the left. The solid red thicker one.
ElsaWin doesn't show pictures on a 2003 Jetta.
Fuse & Relay PDF Files
They want you to post an introduction here-
Large Metal Fuses, from left to right w/ corresponding amperage:
- Generator (alternator) = 110A for 90A alt or 150A for 120A alt
  • Interior Relay = 110A
  • Coolant fan and control module = 40A
  • Glow Plug Relay = 50A
- Coolant pre-heat relays = 50A
