I wouldn't spend money on big ticket repair items unless they were known to have a problem. The turbo and oil chain last a long time and while they do go bad, these often last the life of the car, beyond 200,000 miles. I've heard the oil chain does wear out and maybe this is where you heard this suggestion but unless you're already in there, I wouldn't. If it does fail then it can wipe out the area but unless you have the chance to inspect it (it's inside the oil pan), I wouldn't go to the trouble of inspecting it. The clutch system can also develop wear issues after high mileage but to replace some of the components requires transmission removal -again, way too much work for preventative maintenance.
Something like new suspension bushings and struts, regular engine maintenance, and regular cleaning is a better idea for enjoying a TDI long life. You shouldn't drive the car expecting the worst.
