1 - 7 of 7 Posts
hi, the scanner readout suggests "boost pressure fault". no lights on dash.
so far the garage has
1. cleaned the turbo
2.new MAF
3.checked high pressure/vacuum pipes
4. changed N75
5. cleaned EGR valve
i am at a loss now, has anybody got any suggestions what to do next ?
if i stay under 60mph there is no problem, it drives and accelerates like normal.
What did you scan it with? A generic scanner or VAG-COM\VCDS?
VAG Error Code: 17965/005463
EOBD II Error Code: P1557
Fault Location:
Charge Pressure Control - Positive Deviation
Possible Cause:
Reduced power output.
Limp mode.
Limp mode: What is it, what are the causes, and how to fix it for the Audi and VW TDI diesel turbo.
Boost Pressure too High.
Hoses/Pipes incorrectly connected, disconnected, blocked or leaking.
Charger Pressure Control defective.
Variable Nozzle Turbo (VNT) nozzles stuck.
Solenoid Valve for Boost Pressure Control (N75) defective.
Possible Solutions:
Check Hoses/Pipes to/between Components.
Check Solenoid Valve for Boost Pressure Control (N75).
Check/Clean/Replace Charge Pressure Control.
Check/Clean mechanism for variable nozzles.
I bet there's a hole in one of the lines running to/from your turbo. I had this happen on my old Jetta and it was a hole in the lower intercooler pipe. Easy fix!
Discussion Starter #6
thanks kenneth, i think you might be right, only on first sight, no tears or holes were visible. i am leaving the van at the garage while i am away for 10 days and i mentioned the pipes. i really can not think of anything else. i changed all the sensors, cleaned ad checked all the components, including the turbo itself. nothing sticks, all moves as it should when vaccum or pressure is supplied.
thanks again
thanks again
Hi did you sort the issue you had? Have the same problem. Cheers
1 - 7 of 7 Posts
