Hello can someone please assist with some knowledge... When i press my accelerator the car does not respond... It stays at 1200 idling but when i switch off and start again with the pedal pressed down it revs up and down then it goes to idle again no more response
Try a throttle readaptation.
1. Key on (without starting)
2.hold pedal down to floor for 10 seconds
3. While holding gas turn key off
4. Let off of pedal
5. Key on (do not start) for 5 minutes. Touch nothing! Will hear throttle adapting and doing weird stuff.
6. Start car, touch nothing.
4. Let off of pedal
