Hi there,
Quick introduction as I am currently restoring 3 VW Eos's in Rugby, England.... All have various problems, but the plan is to have them up and ready for the Summer. I have:
2006 2.0TDi with 113,000 miles - Red / Cornsilk
2006 2.0TFSi with 58,000 miles - Black / Black
2007 2.0TFSi with 68,000 miles - Black / Cornsilk
I've already done a full service on the TDi, it had a problem with the glow plug light flashing occasionally and error codes for all glow plugs - ground to short. A quick replacement of the Glow Plug Relay sorted that one out. I replaced all the glow plugs afterwards too.
Occasionally, I get a dash warning requiring it to be taken to the shop - P0401 Exhaust Gas Recirc. Flow: Insufficient Detected... So, I need to strip off the EGR Valve / Cooler and give that a good clean out.
I was also getting a engine issue under acceleration in 3rd gear, it was cutting power quite violently. No faults shown, but I replaced both front ABS Sensors and problem solved. I think it was the OSF that was failing, within tolerances, but the computer was thinking the wheel was skidding. Again, a really cheap fix.
Otherwise, it's a good car, just needs a really good clean and detailing - which is what I'm good at!
Hopefully I can be of assistance to the forum too. I use both VCDS and Launch Diagnostics.
Simon
Simon
