Hi, the other day my car was suddenly dead. everything was dark, i measured about 11.7V.
got help with booster and the car was okay. charged it that night and it was okay the day after. the next day while going home from work all went dark again and i had to use booster. changed to a new battery when i got home and everything is still dark.
all the fuses are ok, new battery is full. and the old battery also seems okay after i took it of the car(12.8V).
any ideas what it could be?
How long is a piece of string?
You need the battery checking out under a load test.
You need a good cranking speed 280 rpm or greater.
Check all connections on the battery and clean them, check you have a good engine earth.
