Ok Guys and Girls,
This can be the definitive thread to how to fix the 2.0 TDI BMN / BKD engine judders / misfires at idle. Because I am so frustrated with this problem, I am going to find a solution!!!!!
The Car: Golf v 2.0 tdi GT 170 BMN engine
For the last several months I have suffered from the common judder /misfire / strange idle problem.
VW diagnosed this problem as a Dual mass flywheel malfunction. However the car was still driveable so I thought I would just live with it.
My mpg has got so bad recently that it thought it was time to get it sorted.
A new DMF, and guess what, the problem is still there. I currently cannot achieve better than 31 mpg.
VCDS measuring blocks show that injector 3’s flow rate is completely off compared to the others so this is my next point of call.
I am going to remove the injectors and get them all tested / serviced if needed than with new seals re-install them.
I need your help though people.
Has anyone got access / a copy of the correct repair manual for this BMN engine regarding the injectors and the cam timing (which, after the injectors is my next step)???
Russ
Russ
