Nice pdf file cheers.
EOBD II Error Code: 01221
Fault Location:
Crash Sensor Side Airbag; Driver Side (G179): No or Incorrect Basic Setting / Adaptation
Possible Cause:
Airbag Warning Light ON.
Wrong Crash Sensor Side Airbag; Driver Side (G179) installed.
Possible Solutions:
Install correct Crash Sensor Side Airbag; Driver Side (G179).
Special Notes:
The Crash Sensors can be checked by using the control module identification and the measuring blocks.
Address 15: Airbags
Controller: 1T0 909 605
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
The 0506 in this example stands for the required Crash Sensor ID, the first 2 digits (05) apply for the front crash sensors, while the second 2 digits (06) apply for the rear crash sensors. The ID of the currently installed Crash Sensors can be determinded by checking Measuring Value Block (MVB) 009.
Fault Location:
Crash Sensor Side Airbag; Driver Side (G179): Faulty, Open Circuit / Short to Plus
Possible Cause:
Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) faulty.
Airbag Control Module (J234) faulty.
Possible Solutions:
Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179).
Replace Crash Sensor Side Airbag; Driver Side (G179).
Replace Airbag Control Module (J234).
As taken from my
http://www.myturbodiesel.com/forum/f9/free-eobd-ii-error-codes-software-2919/
