I see fragmented threads about the post dead battery (renewal) reprogramming that is required for the steering wheel sensor, the panoramic sun roof, the auto window and pinch protection function... However, what is the impact to the VCDS, with regards to setting changes: power window open/close from the remote key fob, euro light switch mod settings, disabling daytime running lights...? Does the VCDS have a "keep alive memory" system that holds these settings or are all of these customized settings lost?
I ask, because it would be most inconvenient to have to bring in my laptop to reprogram the VCDS while renewing a dead battery in a parking lot where the death of the battery occurred. I am not concerned about the loss of the convenience settings (windows...), but if the euro headlight switch mod requires VCDS programing and the customized VCDS programing are lost, will you loose headlight control with the euro switch mod until the VCDS is reprogrammed? I want to ensure that I don't customize my 2011 JSW TDI beyond a 'practical' limit.
