I am finishing up a timing belt change on my 03 jetta tdi and have followed all of this forums directions for this procedure. I am no mechanic but I thought that you normally follow a certain pattern when reinstalling the bolts in the valve cover. I didn't see anything about this in the directions and have searched this website for answers. Hopefully you can tell me how I should proceed with installing the valve cover bolts. Also, should I be concerned with using an elbow on my 5mm socket to reach the 2 hard to reach bolts? Concerned with how this will affect the torque values when using the torque wrench? Make sense?
The elbow will change the torque but it shouldn't leak. Just don't overtighten them. I'm not sure the pattern and I haven't seen a pattern mentioned in the manual. Outer in diagonally should work. These are not bolts that will cause engine failure if they back out a little bit.
Well I don't know this particular engine details but the same procedure would apply to a cylinder head start of in the middle and work your way to the outside diagonally. If some pins are hard to get at then use a universal/elbow joint as stated.
Again the torque setting isn't critical they are just nipped up.
Camshaft cover: 10Nm
