Turn off DRL.
Disable seat belt chime disable.
Door open chime disable.
Adjustable footwell lighting.
Fogs as DRL.
Turn on the hazard flashers if your ABS kicks on from hard braking.
There is other stuff that isn't enabled because you need extra equipment. You can also look here
http://forums.vwvortex.com/showthread.php?4743553
Address 09 - Central Electronics:
Note: If this module does not communicate, unlock all vehicle doors and try again.
Windows up via remote
Comfort Operation (via Remote Control) found in Adaptation. Channel 6, change the value to 1 (On) and Save.
Note: On the 2010 A3 models changing the Adaptation value of Channel 6 may only enable an additional menu in the DIS (MFA). It may be necessary to activate this using the dash menu and selecting Display Type > Set > Windows > Convenience > Automatic. Please see: Audi A3 - Windows Up via Remote Control (Comfort Windows)
Daytime Running Lights
Found in Coding, Long Coding helper, the lamp systems are different:
- Factory Xenon – Byte 11
- Factory Halogen – Byte 15
Cornering Lights via Front Fog Lights active
Note: The headlights must be turned on and the steering wheel must be in the turning direction for this to work.
The lights may also work under the following conditions: Headlights on, fogs off, turn signal on in the turning direction.
Fogs as Daytime Running Lights for Xenon equipped vehicles
Fogs only
Byte 11 - un-check "Daytime Running Lights (via Low Beam) active"
Byte 14, Bit 1 - Manually modify the binary value from a "0" to a "1"
Fogs and Xenon Headlights as DRLs at the same time for Xenon equipped vehicles
Byte 11 - leave this alone (DRL's on)
Fogs as Daytime Running Lights for Halogen equipped vehicles
Disable Factory Halogen DRL's in Byte 15 - un-check "Daytime Running Lights (via separate lights) active"
Notes:
- Depending on the Byte 18 coding, this may result in all of the parking lights illuminating.
- If you do not have desirable results on Halogen equipped vehicles, please update this thread.
Alarm Confirmation via lights and horn
Found in Coding, Long Coding helper.
Comfort Turn signals
Found in Adaptation. From the drop down list, choose the number of flashes and Save.
Emergency Brake Warning active
This actually uses the 4 ways flashers, not a flashing of the brake lamps.
Auto-Lock
Coming Home
If the vehicle is not equipped with an "Auto" headlight switch, coming home activation will likely require you to pull the high beam stalk back briefly after shutting the vehicle off and before exiting. The description should be found in your owner's manual.
Leaving Home
Leaving home will likely require the "Auto" switch and a light sensor. The description should be found in your owners manual.
Auto Closing Sunroof & Windows via Rain Light Sensor (need rain light sensor)
