Not sure about upgraded turbos, I'll try to put together a chart. Of the top of my head, not sure the CFM but it can handle about 15-20 psi in normal driving, stock setup.
More specs below.
COMPRESSOR STAGE:
Wheel Trim - 56
Wheel Diameter (inch)
inside dia. - 1.29
outside dia. - 1.73
Hsg A/R - 0.33
Max Flow - 18 pounds per minute
TURBINE STAGE:
Wheel Trim - 70
inside dia. - 1.42
outside dia. - 1.69
Turbine A/R - 0.65
COMPRESSOR CONFIGURATION (inch):
Hose inlet - 1.75
Hose outlet - 1.50
TURBINE CONFIGURATION:
Hose inlet: 3 bolt inlet
Hose outlet: 3 bolt outlet
