So I happen to pull apart a 98 Beetle Tdi ALH tonight that I basically got for free. I have a 04 Jetta Tdi BEW with a bad kp39 turbo. My question is what is required to use the good ALH turbo on my BEW. Any input would be appreciated.
Thanks
Wes
Sent from my LM-X420 using Tapatalk
Manufacturer: VW, Date(s) Used: 11/1998-06/2004, Model: Jetta, Engine Code: ALH, 66Kw, 90PS, 1.9 Ltr, 4 Cyls, Remarks: USA ("USA"): Turbocharged Direct Injection (TDI) Timing belt
Manufacturer: VW, Date(s) Used: 07/2003-01/2005, Model: Jetta, Engine Code: BEW, 74Kw, 100PS, 1.9 Ltr, 4 Cyls, Remarks: USA ("USA"): Turbocharged Direct Injection Pumpe Düse (TDI-PD) Timing belt
