I have a 2004 Jetta TDI. The yellow engine light came on and stays on. Got a code: P2564: Failed Turbo boost position sensor Engine runs fine. Performance is normal. No turbo lag. What is my problem ?
Plz give step by step instructions on how to do this...i would like to check but dont know how.If you have the time and a laptop computer, I would buy a VCDS cable and look at its function through the VCDS Ross tech diagnostic software. That will tell you right away if the sensor is bad.
