I have a womp womp in my front end sounds like the drivers side. I have replaced the 2 cv axles and replaced the right front wheel bearing and the sound is still there. A mechanic at the V/W place said it might be a bad tire. I do not believe it is a tire. With the right side wheel off I started the motor and put in gear and raced up the motor to about 50 miles per hr and no racket, When I let up on the fuel pedal and it shifted down it made a racket in the last down gear. I think I Need to pull the trans, is this hard to do. I am a retired farmer and have worked on almost everything connected to farming but not a V/W. Any suggestion what might be wrong? It is an automatic transmission
Carhop
Carhop
