I've read the sticky for changing transmission fluid. Problem is when I did mine, I dont think I have the tube that protrudes into the transmission to set the level. When I removed the plug 3.75 quarts of fluid drained and there was nothing in the transmission case to remove.
I replaced with 3.75 quarts to ATF since I have no other way to determine if level is high or low. Tranny shifts much better now and doesnt whine as if it were low on fluid.
I have a 2004 Jetta PD with the 09A transmission. Is it possible that some "genius" in the past did a transmission service for a previous owner and just didnt put the tube back it. Any idea where I can get one. I've searched all the parts dealers online and no luck so far. Thanks!
