1 - 7 of 7 Posts
I know my torsion value is a bit far out but the timing belt was done by the previous keeper about 20,000 miles ago.
Its a 2004 VW Caddy van. Engine code BJB. 105bhp.
The torsion value is -3.4.
The van always seemed a bit low on power but I've since fitted a bigger turbo etc and now puts out 190 bhp.
Am I right in thinking I need to adjust the torsion value a bit. What I'm wondering is how much of an effect does it have on performance.
Many Thanks Aaron.
Sounds like you are out of spec. and that would affect power. If I recall correctly, the spec is -3 to +3 with good power at a setting of zero to +2.
I have adjusted the timing a bit and all i can say is wooooooo. Its made it even quicker. Time to hit the rolling road again.
I had a similar issue after a head gasket replacement. Was running at -2degrees., after setting to 0 degrees, the car flies.
What a difference.
1 - 7 of 7 Posts
