04 Jetta with Triptronic 5 speed auto. At 175K had fluid changed, was having some issues with upshift to 2nd or 3rd. No improvement, check engine light will flash and shift won't always happen until dead middle temp reached on coolant. Usually no problems then. Sometimes no check and no shift problems at all, for days. Then it might not want to shift this afternoon when I leave for home from work. When engine good and cold, problems occur more often, but not 100% of the time.
Error code indicates failure in 2 or 3rd gears (you think???). Local dealer is worthless here in central Arkansas.
Ideas?
Ideas?
