I went to change the oil the other day and noticed that it was a lot more wet than normal. I think I have gone from a seep to a leak. Its all wet underneath the engine, how do I locate the exact leak?
First, clean the engine. Try to cover up electrical connectors and the alternator, remove the battery. This is a good time to clean the whole engine bay. Spray with degreaser and soapy water. It will make finding the leak 1000 times easier.
The problem is that once there's a leak, air blows the oil all around. So sometimes oil moves down, sometimes it moves towards the back of the car.
Try looking at the back of the valve cover and the EGR weep hole.
It depends, probably not. If the leak is on the outside of the turbo from an oil feed line or return line, which is likely as the car get older, no runaway but the lines should be replaced.
If the leak is internal it probably won't be on the outside of the turbo as much unless it's really bad but will cause a runaway.
The turbo can leak but if the exhaust is normal and not smokey, it's probably an external leak. The EGR weep hole often leaks oil, this is very common. As it drips down, it coats the back of the engine.
I know that there are dyes that you can add to the oil, not sure if it's approved for diesels. The idea is that you add a dye, drive the car, and then use a special light to see where the dye has stained the exisitng oil leaks.
They use a UV or blacklight to detect the dye. Some have special tinted glasses to make the colors stand out more. I don't see why it wouldn't be compatible with diesel oil but I would change it out as soon as you can just in case. If the leak is bad, you don't want it dripping down onto the hot exhaust either.
If you're really concerned about the turbo, take off the turbo intake and exhaust piping right next to the turbo and take a look. If it's wet then you have an oil leak. If it's dry then you don't.
Yep, there is a small pinhole leak on the underside of the intake manifold. The head gasket looks dry but the back of the engine is wet and the oil pan area looks wet.
I have 1995 Cabrio with an AAZ swapped into it. Recently, I've been having starter troubles and am looking into some options as far as new starters go. I'm not sure exactly what starter is in there currently, but I did some reading on forums and such and it looks like a lot of people are saying...
I have a 2005 VW Passat w/ the 2.0 TDI BHW. Wife was driving car and the low oil press. light came on, so she drove 5 min to get home. I installed a new oil press. sensor and a new oil filter. Then ran the engine a few mins and concluded: no oil pressure. I read online about the balance shaft...
Hello,
can someone told me, is my MAF sensor bad?
Car is Audi 80 B4, 1.9 tdi 66kw, 1z engine, and works normaly and no problems with speed or with nothing.
But some days ago, the car shut down while driving, and after that works normally like before. But today again, the car shut down while...
having sorted out a duff fuel temp sensor later in the day car starts to rock at tickover so removed oil cap and
i have vcds lite unregistered in measuring blocks group 4 i read
882 rpm 1.3 btdc 0.9btdc
1176rpm 0.4 atdc 0.4 atdc
do u think timing is out
or are piston rings shot
i...
I'm a stickler for clean interiors, and I really want to make it feel nice inside. am I able to swap the seats with a newer car? It doesn't even have to be a VW. Does any one have experiencing replacing their seats?
