I changed the timimg belt using the diy procedure and it was a life saver. I tensioned the belt according to the instructions and turned the engine over manually a couple times. The tension was then low, so I reset it using the procudure. The car starts and runs fine, but when I have checked the belt tension a couple times since, it is always on the high side of the window. Is this normal? If not, can I readjust the tension with the upper timing belt cover removed, or do I need to take it all apart and do it with the lock pins in etc.?
Congratulations on the successful operation!!
On the ALH engine, the tension on the tensioner must only be checked (and adjusted) on an overnight-cold engine... I imagine things are the same on your model, so if your other observations were done on a warm (expanded) engine, I would ignore them.
All the best,
Yuri
