Hey all,
Wanted to post this in a more visible place, since I haven't found anything on it. It's a major question about the timing belt job on my ALH Jetta.
I was locking everything up (all the locks are in right now), and found something that worried me. I set the cams to horizontal, turned the crank to TDC, tried to put the cam lock tool in... and it wouldn't go in. Instead, the cam lock goes in when the mark on the flywheel is a good 3/8" forward of the mark on the casing. Is this normal? The ignition pump pin goes in just fine. I'm afraid to take the timing belt off with it like this. The confusing part about this is that I got 45 mpg on the way back from the guy's house with it, so I don't think the timing belt jumped a tooth. What's going on here? All the locks are in right now, it just doesn't show TDC on the flywheel.
