I began my timing belt project earlier tonight and I am stuck with a problem. I got all the way to the point where I have to rotate the engine to TDC. I used the VW tool to rotate the engine my the camshaft sprocket. When I did the belt slipped over the camshaft teeth. The camshaft rotated and slipped teeth and the engine did not. Luckily I marked on the sprocket and the belt just to be safe. Now the camshaft is off time by about 8 teeth. All the other timing is still good just 8 teeth off on the camshaft. So the question is, how do I get the cam lined back up with my marks so I can continue? Or how could I continue the project and make sure the cam is in time later?
Thanks and any replies soon would be appreciated
