Hi I’ve just changed timing belt all idler pulleys and water pump.Restarted car and it’s come up with p1600 camshaft crankshaft alignment fault.Done 200-300 miles in it and starts first time any ideas what I’ve done ?Gates kit ,water pump and sensor were different to oem one?
Do you mean p0016?
Recheck your timing if that’s the case
What was P1600 scanned with as it doesn't relate to the component you say, as asked?
Recheck the timing belt if it only showed since then?
