Hi everyone!
I have this 2001 jetta tdi that has lower than expected power. Here is a list of things done or checked in the past year or so:
regular upkeep (brake, tires, regular oil changes etc...)
fuel pump timing (somewhat scattered but within spec)
intake manifold cleaned.
turbocharger was checked for sticky vanes
new wastegate actuator and its vacuum valve.
None of these really did the trick. With the idea that a weak fuel pump may not deliver as much fuel as it should (the scattered timing as symptom) I replaced the stock nozzles with 205s (generic... i did not read this forum yet).
The power did go up after appropriate re-tuning, but now there's a a positive pressure deviation in the intake manifold. The car performs well until one requests a bit more power, at which it sets the code and shuts off the turbo. Restarting solves the turbo shutoff, and the code is cleared within a day of driving.
From logging the pressure seems to go well above 1200 mbar and the setpoint is 1020 mbar (if I remember correctly).
I have the impression that it is mechanically fine but there's some subtlety in the programming I'm missing:
With more fuel there is the necessity of more airmass delivery, which is easily achieved with higher pressure. If the ECU lookup table remains unvaried the controller will detect an overpressure. (two lines with different slope will eventually diverge beyond tolerance)
I seem not to find a way to access neither lookup table nor pressure setpoint... which tells me my reasoning is wrong somewhere.
Does anybody have an idea? Suggestions?
Thanks
Thanks
