1 - 20 of 91 Posts
Hi guys.
Some of you may know that I make programmes in Visual Basic Free EOBD II Fault Codes Software, Conversion Utility, Motorcycle Technical Data
Many years ago I made a Timing Belts app for work with 410 pictures and all the data for changing a timing belt for 39 manufacturers and their 500 models.
I know there is a lot of info in FAQ for changing your timing belt which is excellent I'm not knocking that but there are some TDI timing belts that aren't covered. I was thinking of making a TDI Only Timing Belt app.
So I need your comments and suggestions if its worth making this app.
Now its not going to be easy and it won't happen in a few weeks as I can't copy and paste the info anymore.
This app now covers 302 TDI and diesel models.
If you think this app is useful please click the Like link.
20/10/2015 - Update.
Download site changed and change the name to TDI Timing Belts App.
Mega.nz have changed their download links so I've posted the new update.
Mega is being a pain in the backside it now says I need to update my web browser. It shows the link to all browsers, if I click IE it says update to IE 11 which I've always used. I have Firefox as a backup and it work on there no problem.
It should be ok as it only uses a database to store the makes, models and engine codes there are no special ocx files. So you must have
Program Files\Common Files\Microsoft Shared\DAO\dao360.dll in your system, just the same as EOBD II Fault Codes.
I'm trying to sort out all the diesel engine pictures first I have 45 full size ones at the moment from:
LT 2.4D/Turbo D 1978-92 to Golf GTD 2.0D TDI CR 2009-11
The pictures are relatively easy its just typing in all the data for each one, as I said it will take weeks. I was just after comments whether it would be useful obviously for Audi, Seat and Skoda users.
Discussion Starter #4
Come on guys I added another 35 timing belts to the app.
I need comments if its useful?
The app is too big to add in here just to show you whats available. I would move this thread to members only.
Its been viewed 100 times.
6 views and still no comments. :bangshead
I've finished all 76 SEAT models:
Alhambra 1.9D TDI 1996-99 - 1Z, AFN, AHU, AVG
Alhambra 1.9D TDI PD 2000-10 - Mechanical Tensioner - ANU, ASZ, AUY, BTB, BVK
Alhambra 1.9D TDI PD 2000-10 - Hydraulic Tensioner - ANU, ASZ, AUY, BTB, BVK
Alhambra 2.0D TDI PD 2005-10 - BRT, BVH
Altea/Altea XL 1.9D TDI PD 2004-09 - 2004 - BJB, BKC, BXE
Altea/Altea XL 1.9D TDI PD 2005-10 - 06/2005> - BJB, BKC, BXE
Altea/Altea XL 1.9D TDI PD 2005-10 - 2005-05/2005 - BJB, BKC, BXE
Altea/Altea XL 1.9D TDI PD 2006-10 - BLS
Altea/Altea XL 2.0D TDI PD 2004-11 - AZV, BKD
Altea/Altea XL 2.0D TDI PD 2006-11 - BMM
Altea/Altea XL 2.0D TDI PD CR 2009-11 - Timing Gears - CEGA
Altea/Altea XL 2.0D TDI PD CR 2009-11 - CEGA
Arosa 1.4D TDI PD 1999-05 - <2002 Hydraulic Tensioner - AMF
Arosa 1.7D SDI PD 1998-05 - AKU
Cordoba 1.4D TDI PD 2002-09 - AMF, BMS, BNM, BNV
Cordoba 1.7D SDI 1996-99 - AKW
Cordoba 1.9D 1993-99 - Manual Tensioner - 1Y
Cordoba 1.9D 1993-99 - Automatic Tensioner - 1Y
Cordoba 1.9D SDI 1996-99 - AEY
Cordoba 1.9D SDI 1999-02 - AGP, AQM
Cordoba 1.9D SDI 2002-06 - ASY
Cordoba 1.9D TDI 1996-99 - 1Z, AFN, AHU
Cordoba 1.9D TDI 1999-02 - AGR, ALH, ASV
Cordoba 1.9D TDI PD 2002-08 - ASZ, ATD, AXR, BLT, BMT, BPX, BUK
Cordoba 1.9D Turbo 1993-97 - Automatic Tensioner - AAZ
Cordoba 1.9D Turbo 1993-97 - Manual Tensioner - AAZ
Ibiza 1.4D TDI PD 2002-09 - AMF, BMS, BNM, BNV
Ibiza 1.7D 1985-93 - 022A 5000
Ibiza 1.7D SDI 1996-99 - AKW
Ibiza 1.9D 1993-99 - Automatic Tensioner - 1Y
Ibiza 1.9D 1993-99 - Manual Tensioner - 1Y
Ibiza 1.9D SDI 1996-99 - AEY
Ibiza 1.9D SDI 1999-02 - AGP, AQM
Ibiza 1.9D SDI 2002-06 - ASY
Ibiza 1.9D TDI 1996-99 - 1Z, AFN, AHU
Ibiza 1.9D TDI 1999-02 - AGR, ALH, ASV
Ibiza 1.9D TDI PD 2002-08 - ASZ, ATD, AXR, BLT, BMT, BPX, BUK
Inca 1.9D 1996-04 - Automatic Tensioner - 1Y
Inca 1.9D 1996-04 - Manual Tensioner - 1Y
Inca 1.9D SDI 1996-04 - AEY, AYQ
Leon 1.9D SDI 2000-05 - AGP, AQM
Leon 1.9D TDI 1999-05 - AGR, AHF, ALH, ASV
Leon 1.9D TDI PD 2000-05 - Mechanical Tensioner - ARL, ASZ
Leon 1.9D TDI PD 2000-05 - Hydraulic Tensioner - ARL, ASZ
Leon 1.9D TDI PD 2002-08 - ASZ, ATD, AXR, BLT, BMT, BPX, BUK
Leon 1.9D TDI PD 2005-10 - 2005-05/2005 - BJB, BKC, BXE
Leon 1.9D TDI PD 2005-10 - 06/2005> - BJB, BKC, BXE
Leon 1.9D TDI PD 2005-10 - BJB, BKC, BXE
Leon 1.9D TDI PD 2005-10 - BLS
Leon 2.0D TDI PD 2005-11 - 2005-05/2005 - BMM
Leon 2.0D TDI PD 2005-11 - 06/2005> - BMM
Leon 2.0D TDI PD 2005-11 - AZV, BKD
Leon 2.0D TDI PD FR 2006-09 - Early type (tensioner adjusted with two-pin wrench) - BMN
Leon 2.0D TDI PD FR 2006-09 - Late type (tensioner adjusted with Allen key) - BMN
Leon 2.0D TDI PD FR 2006-09 - 2005-05/2005 - BMM
Malaga 1.7D 1985-93 - 022A 5000
Ronda 1.7D 1985-93 - 022A 5000, 138 A5.000
Terra 1.3D 1990-95 - MN
Terra 1.4D 1990-95 - 1W
Toledo 1.9D 1994-99 - Automatic Tensioner - 1Y, AAZ
Toledo 1.9D 1994-99 - Manual Tensioner - 1Y, AAZ
Toledo 1.9D TDI 1995-99 - 1Z, AFN, AHU
Toledo 1.9D TDI 1999-05 - AGR, AHF, ALH, ASV
Toledo 1.9D TDI PD 2000-05 - Hydraulic Tensioner - ARL, ASZ
Toledo 1.9D TDI PD 2000-05 - Mechanical Tensioner - ARL, ASZ
Toledo 1.9D TDI PD 2002-08 - ASZ, ATD, AXR, BLT, BMT, BPX, BUK
Toledo 1.9D TDI PD 2004-09 - 06/2005> - BJB, BKC, BXE
Toledo 1.9D TDI PD 2004-09 - 2005-05/2005 - BJB, BKC, BXE
Toledo 1.9D TDI PD 2004-09 - 06/2005> - BLS
Toledo 1.9D TDI PD 2004-09 - 05/2005 - BLS
Toledo 1.9D TDI PD 2004-09 - BJB, BKC, BXE
Toledo 1.9D Turbo 1993-97 - Automatic Tensioner - AAZ
Toledo 1.9D Turbo 1993-97 - Manual Tensioner - AAZ
Toledo 2.0D TDI PD 2004-09 - 2005-05/2005 - BMM
Toledo 2.0D TDI PD 2004-09 - AZV, BKD
Toledo 2.0D TDI PD 2004-09 - 06/2005> - BMM
Thats fine just wait for the next version.
So you have Windows 7 as well as Vista 64bit. Is the Windows 7 64bit if it is then EOBD II Fault Codes should work on Windows 7 64bit but you have to run it as an Administrator.
I'm going through the 27 Skoda models at the moment:
Fabia 1.4D TDI PD 2003-07 - AMF, BNM, BNV
Fabia 1.9D SDI 1999-06 - ASY
Fabia 1.9D TDI PD 2000-07 - 05/2001> - ATD
Fabia 1.9D TDI PD 2000-07 - <04/2001 - ATD
Fabia 1.9D TDI PD 2005-07 - AXR
Fabia 1.9D TDI PD vRS 2003-07 - ASZ, BLT
Fabia II 1.4D TDI PD 2007-10 - BMS, BNM, BNV
Fabia II 1.4D TDI PD (GreenLine) 2008-10 - BMS
Fabia II 1.9D TDI PD 2007-10 - BLS, BSW
Felicia/Felicia Pick-up/Felicia Cubic Van 1.9D 1995-01 - AEF
Octavia II 1.9D TDI PD 2004-10 - BJB, BKC
Octavia II 1.9D TDI PD 2006-10 - BLS, BXE
Octavia II 2.0D TDI PD 2005-11 - BMM
Octavia II 2.0D Vrs TDI PD 2005-09 - BMN
Octavia/Octavia Tour 1.9D SDI 1997-05 - AGP, AQM
Octavia/Octavia Tour 1.9D TDI 1996-05 - AGR, AHF, ALH, ASV
Octavia/Octavia Tour 1.9D TDI PD 2003-11 - ASZ, ATD, AXR
Roomster 1.4D TDI PD 2006-10 - BMS, BNM, BNV
Roomster 1.9D TDI PD 2006-10 - AXR, BLS, BSW
Superb 1.9 TDI PD 2002-08 - <2002 with Hydraulic Tensioner - AVB, AVF, AVX, BPZ, BSV
Superb 1.9 TDI PD 2002-08 - 2002> with Mechanical Tensioner - AVB, AVF, AVX, BPZ, BSV
Superb 2.0D TDI PD 2005-09 - BSS
Superb 2.5D TDI PD 2002-08 - AYM, BDG
Superb II 1.9D TDI PD 2008-11 - BLS, BXE
Superb II 2.0D TDI CR 2008-11 - CBBB
Superb II 2.0D TDI PD 2008-11 - BKD, BMP
I did post Audi A6 (97-05) 2,5D TDI 1999-02 Engine code: AKN a few months ago.
Discussion Starter #10
It isn't an easy job as it would have been but I will get there.
Discussion Starter #12
Yes Polo 1.4D TDI PD 1999-02 - AMF will be in there.
In fact its in there at the moment.
Ok I've only had 4 download of this app and only Chitty has made a comment
I've updated this app so you can try it out to see if its any good and if it would be useful to complete all 287 models.
Link is in Post #1
Run the link and click on the green Download button under the computer then click on Free Download and save the TDI_Timing_Belts.zip somewhere.
As I've said I finished all 25 Seat models and all 15 Skoda models so I remove the *** from those lists. Any of the others that have *** in the model listing those are finished. I've removed the picture name so that doesn't show on the printout. I haven't decided what main app picture to show any suggestions will be appreciated?
Just extract both files to a folder where you have admin rights scan it for a virus and malware because you don't really know me.
Please post comments if you like it or if you find any problems?
Ok I've finished the 63 Audi models:
100 2.0D 1978-89 - CN
100 2.0D Turbo 1982-91 - DE, NC
100 2.4D 1991-94 - ASS
100 2.4D 1992-91 - 3D
100 2.5D TDI 1991-94 - AAT
100 2.5D Turbo 1990-91 - 1T
100 2.5D Turbo 1991-92 - ABP
200 2.0D Turbo 1982-87 - DE
80 1.6D 1983-86 - JK
80 1.6D Turbo 1982-86 - CY
80 1.9D 1989-91 - 1Y
80 1.9D TDI 1991-96 - 1Z
80 1.9D Turbo 1991-94 - AAZ
80/90 1.6D Turbo 1986-91 - RA, SB
A2 1.2D TDI PD 2001-06 - ANY
A2 1.4D TDI PD 2000-06 - AMF, ATL, BHC
A3 1.9D TDI 1996-03 - AGR, AHF, ALH, ASV
A3 1.9D TDI PD 1997-03 - 2002> Mechanical Tensioner - ASZ, ATD, AXR
A3 1.9D TDI PD 1997-03 - <2002 Hydraulic Tensioner - ASZ, ATD, AXR
A3 1.9D TDI PD 2003-09 - BLS, BXE
A3 1.9D TDI PD 2003-09 - BKC
A3 2.0D TDI CR 2008-11 - CBAA, CBAB, CBBB
A3 2.0D TDI CR 2009-11 - CFFA, CFFB
A3 2.0D TDI PD 2003-08 - 2005> - AZV, BKD
A3 2.0D TDI PD 2003-08 - <2005 - AZV, BKD
A3 2.0D TDI PD 2004-08 - BKQ, BMN, BUY
A3 2.0D TDI PD 2004-08 - BMM
A3/A5 Sportsback/A5 Coupe/A6/Q5/TT 2.0D TDI CR 2008-11 - Timing Gears - CAGA, CAGB, CAHA, CAHB, CBAA, CBAB, CBBB, CFFB
A4 1.9D TDI 1995-01 - 1Z/AHU, AFF, AFN, AHH, AVG
A4 1.9D TDI PD 2001-06 - <2002 Hydraulic Tensioner - AVB, AVF, AWX
A4 1.9D TDI PD 2001-06 - 2002> Mechanical Tensioner - AVB, AVF, AWX
A4 2.0D TDI CR 2007-11 - CAGA, CAGB, CAGC, CAHA, CAHB
A4 2.0D TDI PD 2004-08 - BLB, BNA, BRD, BRE, BRF, BVA, BVF, BVG
A4 2.5D TDI 2001-08 - AKE, AYM, BAU, BCZ, BDG, BDH, BFC
A4 Allroad 2.0D TDI CR 2009-11 - CAGA, CAGB, CAHA, CAHB
A4 Cabrio 2.0D TDI PD 2005-09 - BRE, BRF
A4 Cabrio 2.5D TDI 2003-09 - BCZ, BDG, BFC
A4 Quattro 1.9D TDI 1995-01 - AFN, AVG
A4 Quattro 1.9D TDI PD 2001-04 - <2002 Hydraulic Tensioner - AVF
A4 Quattro 1.9D TDI PD 2001-04 - 2002> Mechanical Tensioner - AVF
A4 Quattro 2.0D TDI PD 2004-08 - BLB, BRD, BRE, BVA
A4 Quattro 2.5D TDI 2001-04 - AKE, AYM, BAU, BDH
A4/A4 Cabrio 2.0D TDI PD 2005-08 - BRC, BKE, BPW, BRB
A4/A4 Quattro 1.9D TDI PD 1999-01 - AJM, ATJ
A4/A4 Quattro 2.5D TDI 1997-01 - AFB, AKN
A5 Coupe/Cabriolet 2.0D TDI CR 2008-11 - CAHA, CAHB
A5 Sportsback 2.0D TDI CR 2009-11 - CAGA, CAGB, CAHA, CAHB
A6 1.9D TDI 1994-97 - 1Z/AHU
A6 1.9D TDI PD 1998-02 - AJM
A6 2,5D TDI 1997-05 - AFB, AKE, AKN, AYM, BAU, BCZ, BDG, BDH, BFC
A6 2.0D TDI CR 2008-11 - CAHA
A6 2.0D TDI PD 2005-08 - BLB, BNA, BRE, BRF, BVG
A6 2.0D TDIe CR 2008-11 - CAGB
A6/A6 Quattro 1.9D TDI 1997-02 - AFN, AVG
A6/A6 Quattro 1.9D TDI PD 2001-05 - <2002 Hydraulic Tensioner - AVF, AWX
A6/A6 Quattro 1.9D TDI PD 2001-05 - 2002> Mechanical Tensioner - AVF, AWX
A6/A6 Quattro 2,5D TDI 1994-97 - AAT
A6/A6 Quattro 2,5D TDI 1994-97 - AEL
A8 2.5D TDI 1997-02 - AFB, AKE, AKN
Allroad 2.5D TDI 2000-05 - AKE, BAU, BCZ
Cabriolet 1.9D TDI 1995-00 - 1Z/AHU
Q5 2.0D TDI CR 2008-11 - CAHA, CAHB
TT 2.0D TDI CR 2008-10 - CBBB
Lets start having some comments after I've spent many many hours doing this app?
Ok I think I've added all the relevant vehicles in the this app it now shows 286 models now that VW is complete. I'm sure all the data is correct I'm just going to check each one just to make sure. Plus a bit of tidying up to do.
130 VW models.
Beetle 1,9D TDI 1998-04 - AGR, ALH
Beetle 1,9D TDI PD 2000-11 - <2002 Hydraulic Tensioner - ATD, AXR, BSW
Beetle 1,9D TDI PD 2000-11 - 2002> Mechanical Tensioner - ATD, AXR, BSW
Bora (Jetta) 1.9D SDI 1997-05 - AGP, AQM
Bora (Jetta) 1.9D TDI PD 1998-05 - 2002> Mechanical Tensioner - AJM, ANU, ARL, ASZ, ATD, AUY, AXR
Bora (Jetta) 1.9D TDI PD 1998-05 - <2002 Hydraulic Tensioner - AJM, ANU, ARL, ASZ, ATD, AUY, AXR
Bora (Jetta)/Golf 1,9D TDI 1997-05 - AGR, AHF, ALH, ASV
Caddy 1.6D 1980-91 - JK, ME
Caddy 1.7D SDI 1996-00 - AHB, AKW
Caddy 1.9D 1996-00 - 1Y
Caddy 1.9D SDI 1996-00 - AEY
Caddy 1.9D SDI 1998-04 - AQM, AYQ
Caddy 1.9D TDI 1998-03 - ALH, ASV
Caddy 1.9D TDI 1998-03 - AFN, AHU, ALE
Caddy Pick-up 1.9D 1996-00 - 1Y
Caddy Pick-up 1.9D 1996-01 - AEF
Caddy/Caddy Maxi 1.9D TDI PD 2003-11 - 06/2005> BJB, BLS, BSU
Caddy/Caddy Maxi 1.9D TDI PD 2003-11 - <05/2005 BJB, BLS, BSU
Caddy/Caddy Maxi 2.0D SDI 2003-11 - 06/2005> BDJ, BST
Caddy/Caddy Maxi 2.0D SDI 2003-11 - <05/2005 BDJ, BST
Caddy/Caddy Maxi 2.0D TDI 2007-11 - BMM
Caddy/Golf 1,9D TDI 1997-05 - AGR, AHF, ALH, ASV
Crafter 2.5D BlueTDI 2009-11 - CEBA, CEBB, CECA, CECB
Crafter 2.5D TDI 2006-10 - BJJ, BJK, BJL, BJM
Eos 2.0D TDI CR 2008-11 - CBAB
Eos 2.0D TDI PD 2006-10 - BMM
Eos/Golf/Jetta/Passat/Passat CC/Scirocco/Tiguan 2.0D TDI CR 2007-11 - Timing Gears - CBAA, CBAB, CBAC, CBBA, CBBB, CBDA, CBDB, CBDC, CEGA
Fox 1.4D TDI PD 2005-11 - BNM
Fox 1.9D SDI 2005-07 - ASY
Golf 1.9D 1991-96 - 1Y
Golf 1.9D SDI 1995-98 - AEY/AEF
Golf 1.9D SDI 1997-05 - AGP, AQM
Golf 1.9D TDI PD 1998-06 - 2002> Mechanical Tensioner - AJM, ANU, ARL, ASZ, ATD, AUY, AXR
Golf 1.9D TDI PD 1998-06 - <2002 Hydraulic Tensioner - AJM, ANU, ARL, ASZ, ATD, AUY, AXR
Golf 1.9D TDI PD 2004-08 - BJB, BKC, BLS, BRU, BXE, BXF, BXJ
Golf 1.9D TDI PD BlueMotion 2007-09 - BLS
Golf 1.9D Turbo 1991-94 - Automatic Tensioner and Adjustable Pump Sprocket - 1Y
Golf 1.9D Turbo 1991-94 - Manual Tensioner and Non Adjustable Pump Sprocket - 1Y
Golf 2.0D SDI 2004-08 - BDK
Golf 2.0D TDI CR 2008-11 - CBAA, CBAB, CBBB, CBDB, CBDC, CJAA
Golf 2.0D TDI PD 2004-08 - AZV, BKD, BMN
Golf GTD 2.0D TDI CR 2009-11 - CBBB
Golf Plus 1.9D TDI PD 2005-09 - 06/2005> - BKC, BLS, BRU, BXE, BXF, BXJ
Golf Plus 1.9D TDI PD 2005-09 - <05/2005 - BKC, BRU
Golf/Golf Cabrio 1.9D TDI 1993-98 - Automatic Tensioner - 1Z/AHU
Golf/Golf Cabrio 1.9D TDI 1993-98 - Manual Tensioner - 1Z/AHU
Golf/Golf Plus 2.0D TDI PD 2005-08 - <05/2005 - BMM
Golf/Golf Plus 2.0D TDI PD 2005-08 - 06/2005> - BMM
Golf/Jetta 1.6D 1983-92 - JP
Golf/Jetta 1.6D Turbo 1989-92 - 1V, JR, RA, SB
Golf/Jetta/Passat 1.6D 1980-88 - CR, JK, KR
Golf/Jetta/Passat 1.9D TDI PD 2005-09 - 06/2005> - BKC, BLS, BRM, BXE
Golf/Jetta/Passat 1.9D TDI PD 2005-09 - <05/2005 - BKC, BLS, BRM, BXE
Golf/Jetta/Touran 2.0D TDI PD 2005-10 - AZV, BKD, BMN
Golf/Passat 1.9D TDI 1993-98 - 1Z/AHU
Golf/Passat 1.9D Turbo 1991-98 - Automatic Tensioner and Non Adjustable Pump Sprocket - AAZ
Golf/Passat 1.9D Turbo 1991-98 - Manual Tensioner and Non Adjustable Pump Sprocket - AAZ
Golf/Passat/Vento 1.9D TDI 1996-99 - AFN, AHH, ALE
Jetta 2.0D TDI CR 2008-11 - CBDA, CBDB, CEGA
Jetta 2.0D TDI PD 2005-09 - BMM
LT 2.4D 1989-92 - 1S, ACT, DW
LT 2.4D Turbo 1992-96 - 1G, ACL, DV
LT 2.5D SDI 1996-98 - AGX
LT 2.5D TDI 1996-98 - AHD, ANJ, APA, AVR, BBE, BBF
Lupo 1.2D TDI PD 1999-05 - ANY, AYZ
Lupo 1.2D TDI PD 1999-05 - 2002> Mechanical Tensioner - AMF
Lupo 1.2D TDI PD 1999-05 - <2002 Hydraulic Tensioner - AMF
Lupo 1.7D SDI 1998-05 - AKU
Passat 1.6D Turbo 1986-88 - CY
Passat 1.6D Turbo 1988-94 - RA, SB
Passat 1.9D 1989-94 - 1Y
Passat 1.9D TDI 1993-96 - Manual Tensioner - 1Z
Passat 1.9D TDI 1993-96 - Automatic Tensioner - 1Z
Passat 1.9D TDI 1995-96 - AFN
Passat 1.9D TDI PD 1998-00 - AJM, ATJ
Passat 1.9D TDI PD 2001-05 - Hydraulic Tensioner - AVB, AVF, AWX
Passat 1.9D TDI PD 2001-05 - Mechanical Tensioner - AVB, AVF, AWX
Passat 2.0D TDI CR 2008-11 - CBAA, CBAB, CBAC, CBBB, CBDC
Passat 2.0D TDI PD 2003-05 - BGW, BHW
Passat 2.0D TDI PD 2005-09 - BKP, BMA, BMR, BUZ, BVE, BWV
Passat 2.0D TDI PD 2005-09 - 06/2005> BMP
Passat 2.0D TDI PD 2005-09 - <05/2005 BMP
Passat 2.5D TDI 2001-05 - AKN, BAU, BDG, BDH
Passat CC 2.0D TDI CR 2008-11 - CBAA, CBAB, CBAC, CBBB
Polo 1.4D 1990-94 - 1W
Polo 1.4D TDI PD 2002-06 - AMF
Polo 1.4D TDI PD 2002-09 - BAY, BMS, BNM, BNV, BWB
Polo 1.4D TDI PD BlueMotion 2007-09 - BMS
Polo 1.7D 1996-00 - AHG, AKU
Polo 1.7D SDI 1997-00 - AKW
Polo 1.9 SDI 1996-02 - AEY
Polo 1.9 SDI 1996-02 - AGP, AQM
Polo 1.9 SDI 1996-98 - AGD, AHG, ASX
Polo 1.9 SDI 2002-06 - ASY
Polo 1.9D 1995-00 - 1Y
Polo 1.9D 1998-02 - AEF
Polo 1.9D TDI 1997-02 - AFN, AHU, ALE
Polo 1.9D TDI 1999-02 - AGR, ALH, ASV
Polo 1.9D TDI 2003-09 - ASZ, ATD, AXR, BLT, BMT
Polo/Derby 1.3D 1986-90 - MN
Santana 1.6D 1980-88 - CR, JK
Scirocco 2.0D TDI CR 2008-11 - CBBB
Sharan 1.9D TDI 1995-00 - 1Z/AHU, AFN, AVG
Sharan 1.9D TDI PD 2000-10 - 2002> Mechanical Tensioner - ANU, AUY, BTB, BVK
Sharan 1.9D TDI PD 2000-10 - <2002 Hydraulic Tensioner - ANU, AUY, BTB, BVK
Sharan 1.9D TDI PD 2002-10 - ASZ
Sharan 2.0D TDI PD 2005-10 - BRT
Taro 2.4D 1989-94 - 2L
Tiguan 2.0D TDI CR 2007-11 - CBAA, CBAB, CBBA, CBBB
Touran 1.9 TDI PD 2003-10 - 06/2005> - AVQ, BKC, BRU, BXE
Touran 1.9 TDI PD 2003-10 - <05/2005 - AVQ, BKC, BRU, BXE
Touran 1.9 TDI PD 2006-10 - BLS, BXF, BXJ
Touran 2.0D TDI PD 2003-10 - <05/2005 - BMM
Touran 2.0D TDI PD 2003-10 - 06/2005> - BMM
Transporter T4 1.6D 1981-90 - CS
Transporter T4 1.6D Turbo 1984-90 - JX
Transporter T4 1.7D 1984-90 - KY
Transporter T4 1.9D 1990-96 - Automatic Tensioner and Adjustable Pump Sprocket - 1X
Transporter T4 1.9D 1990-96 - Manual Tensioner and Non Adjustable Pump Sprocket - 1X
Transporter T4 1.9D Turbo 1992-03 - Manual Tensioner and Non Adjustable Pump Sprocket - ABL
Transporter T4 1.9D Turbo 1992-03 - Automatic Tensioner and Adjustable Pump Sprocket - ABL
Transporter T4 2.5 TDI 1995-03 - ACV, AHY, AJT, AUF, AXG, AXL, AYC
Transporter T5 1.9D TDI PD 2003-09 - 2006> - AXB, AXC, BRR, BRS
Transporter T5 1.9D TDI PD 2003-09 - <12/2005 - AXB, AXC
Transporter T5 1.9D TDI PD 2006-10 - BRR, BRS
Transporter T5 2.4D 1990-97 - AAB
Transporter T5 2.4D 1997-03 - AJA
Vento 1.9D 1995-98 - AEY/AEF
Vento 1.9D TDI 1993-98 - Manual Tensioner - 1Z/AHU
Vento 1.9D TDI 1993-98 - Automatic Tensioner - 1Z/AHU
So lets finally have some comments please? The new link is in Post #1.
Discussion Starter #17
Well I've only had 4 downloads of the latest version and 2 comments at the moment we will have to see if any more VAG users fancy it?
I've uploaded this app so you can try it out to see if its any good and if it would be useful to complete all 187 models Post #1.
Just downloaded and tried the app. - I am really impressed. The quality is great. Hopefully you will have an update for my 2013 TDI Golf when I need it. Only 4,000 miles so far tho...
1 - 20 of 91 Posts
