I know some of you have helped me here http://www.myturbodiesel.com/forum/f5/tdi-going-into-limp-mode-after-re-con-turbo-3408/#post16220
The best I have managed to do is adjust the turbo actuator stop screw as it was a little on the long side.. have yet to adjust the VNT adjuster tho.
Anyway, I was bored so I though I'd refit the cheapy aftermarket tuning box I've had sitting around (which goes between the ECU & the injector) - all I can say is that it feels like a new car.
It pulls from 1200rpm like it never used to & (because of the stop?) there's not as much lag & it pulls much better through the gears. Doesn't look like there's much in the way of smoke & the MPG has gone from 29 to 43 on a 40min motorway drive Surprise
Best of all, it hasn't gone into limp mode with the -'ve deviation code (or any other for that matter).
AFAIK, these tuning boxes convince the ECU to overfuel. The question I have is why my Tdi wasn't doing the correct fuelling in the 1st place?
Was my ECU knackered or has it been 'adapted' by previous use of this tuning box?
I can't work out why this seems to have solved the problem when the car should be like it without this tuning box.
Can anyone shed any light on this?
Cheers,
Nic
Cheers,
Nic
