Hello everyone. I have kind of an interesting problem and wondering if anyone else has ran into it. I've been chasing a cam position fault on a 06 BRM and my wiring going to ECM and sensor are fine. The main problem is couldnt set my cam torsion value because it wouldn't read. I found a known good sensor and I installed it on the car and I could adjust my torsion value like normal. I have now bought 4 different cam position sensors from different locations and every single one of them didn't work. I'm wondering if anyone has every had this issue and if so where did you get a good sensor without having to spend the $200 that the stealer ship is asking for one!!! Im going to try the one from Kerma TDI which i should have started there but ill let you know.
Thank you for reading,
Cecil
So in case anyone cares or runs into this problem you need to get your cam position sensor from Kerma TDI. Don’t go with any other parts store because they probably won’t work. The one I got from Kerma tdi works great.
