First to say hi.
I am new to this forum. Live in Minneapolis, MN and currently own several TDIs. 2004 JSW, 2004 Golf, 1996 Passat and 1991 Jetta all TDIs except last one being TD. Within our familly we also have 1998 Jetta TDI, 2006 Jetta TDI and 2010 Jetta TDI.
My question is on final procedure when changing TB using Vag-Com.
I am doing my first BEW TB change. I did several ALH TB changes. With ALH Vag-Com was used on the end to fine tune pump/timing by checking and rotating pump. In BEW procedures I am not seeing this step. Does BEW engine not require this final adjustnment with Vag-Com or am I just not reading things right?
Thank you.
Thank you.
