1 - 1 of 1 Posts
2006 VW Jetta TDI (Malone Stage 2)
Vehicle:
2006 Volkswagen Jetta TDI [BRM]
Malone Stage 2
History:
I changed the following items yesterday:
Timing Belt​
Timing Belt Tensioner​
Timing Belt Idler Pulley​
Water Pump​
Camshaft​
Followers​
Oil (15w40 - 505 01)​
Coolant (G11 - yes, I know it’s supposed to be G12)​
Problem:
I am in a constant limp mode state with the OBDII code P0237.
I’m getting tired of this code. There’s nothing wrong with my turbo and the vacuum lines seem fine. I did buy a vacuum tester but I don’t know how to best use it to find my problem if it is to be found at all. I tried clearing all the DTC codes but this time it won’t go away. I have VCDS but don’t really know how I can use that either... I still need to buy a PC to run it on properly... (I’ve used it on boot camp in the past).
I’m young and inexperienced so I’m sorry if this has been hashed out before...
1 - 1 of 1 Posts
