I’m having some trouble trying to track down my issue. I was driving around all morning and my car was running fine. Started up good, drove good and everything else. I drove out to my brothers which is about 40+ miles from home and was fine. Got there, it sat for no more than 30 minutes and drove off. I was driving about 25 miles and came to a rolling stop as the light turned green and continued to go and the car completely loses power. I pull off to the side, and try to turn it over and it cranks but won’t start. It sounds and feels like it wants to. But won’t completely come alive. The glow light comes on for less than a second when I cycle the key and the tac moves. But it won’t start up at all. And it’s not throwing any code. So I’m at a loss. Any help is greatly appreciated
It could be loads of things.
Like updraft said you need to post an introduction and also let people know the model/year at least of your car. Initially it sounds like a 109 relay or lift pump issue but your car might not even have a lift pump depending on the model/year/engine
