1 - 8 of 8 Posts
5 days ago, I went to the grocery store and when I came out the 2000 Jetta 1.9L TDI would not start and would crank like with a weak battery. I walked home about 10 minutes came back and jumped it. The next morning it started and I drove to buy a new battery. It started again I went home and installed the new battery. Since then I've probably started it about 12 times. So then this morning, I start it, drive somewhere, it sits for 10 minutes and then it has the same weak battery syndrome. I cranked it and cranked hoping it would turn over. I opened the hood and there was smoke coming from the starter solenoid connection area with a flame. I blew out the flame. I tried to jump start it. No success, just more smoke. I felt the positive battery cable leading to the starter and it was very hot. I assume I need a new starter. A guy at work says it could be that the alternator is overcharging. What should I do??? :confused:
Most auto parts store will test the battery or alternator for free. Most should have the machine that tests it on the car too. You could have gotten a defect battery
Depending on how hot it is and how long you cranked the engine, it's possible that you fried the starter, causing the smoke.
Another guess- shorted wire is a possibilty. Another guess is stuck starter. The bearings get old and the starter gets clogged with dust, causing it to stay engaged, this acts like a generator and can do crazy things with the electrics. Also the voltage regulator on the alternator could be bad.
Discussion Starter · #4 ·
My plan is to remove the starter, alternator, and battery. I've already bought a new starter so I'll replace it and have the alternator and battery tested. Whatever tests bad I'll replace.
1 - 8 of 8 Posts
