Hi there,
I have two problems:
I have tried two starters and both result in the same problems (I haven't tested them after I've taken them off but they were okay going on). When I turn the key there is a half-second delay in the starter and then it makes a single click and either turns over the car or doesn't.
-what do you think it is? a faulty connection? where would I check? I've cleaned all the wires before putting them on. I've been advised it might be the 'ground' wire but I don't know where that is.
I also have a wobble when I brake. Warped rotor?
Doubly thanks
Doubly thanks
