My Jetta came with standard heated side mirrors and I would like to replace them with signal lights, heated mirrors. Would this be a plug and play installation?
Or would I need to purchase additional items.
The LED strips in side mirrors you can't replace the strip you have to but a new bottom half of the mirror. I had to buy one a couple of years ago when an error code showed but it was working perfectly.
That has been a problem with LED's for years. That is the same for LED lights in a home, you cant buy bulbs you have to buy a new fitting.
If you fitted heated mirrors they aren't plug and play you need access to VAG-COM\VCDS to set them up. Plus you may need another module to control them and additional wiring
Your picture doesn't show..
On a side note the heated mirrors on my Golf only turn on when you turn on the heated rear window.
