Gear shifting was intermittent. Speed sender is the culprit. Replacing it with a new one. I removed the retaining bolt on the end of the sensor, but now I can't remove it. It is moving side to side, but I can't get it out. Help!
Yes, I can rotate it and move it form side to side. I just can't pull it out so I'm wondering if there is a trick that I don't know. I've kept stress on it as I rotate it thinking there may be a notched housing, but it doesn't want to come out.
Like I said, i removed the retaining bolt. As far as I know, it's the only thing holding it in that I can see. You can't unscrew it because it will hit against a frame by the engine. It moves and rotates, but I can't pull it out.
