I have a 2002 bug I had a clutch put in 2 weeks ago and a week ago I got in it and it started then died 2 seconds later it will repeat this for about 5 times then it won’t start at all it will just crank. I have replaced 109 relay and fuel filter. Cheeked the air shut off valve it stays open. The fuel shut off valve clicks when key is turned on and keeps 12 volt even after car dies. I have took a jug of diesel and a clear hose and gravity feed fuel into the injector pump pulled vacuum on return line to bleed it and also cracked injector lines one at a time to bleed them after all that the same thing . All timing marks are lining up I don’t know what ells to do but replace the injector pump. Any ideas.
