Hello.
I have a sharan with a failed oil pump hex key. I have got parts to convert to 1.9 alh pump. I have found a parts list on a page from this forum and i have a problem.
The oil pickup tube is hitting the sump and does not go all the way. I have got a 1.8T Oil pump pickup tube - 06B115251, does 06A115251 fit? It is a bit longer and bent upwards.
Another thing the oil supply to balance shafts i have it plugged but oil baffle has some clips to go in that hole and is routing oil near pickup tube through a passage inside.
This is where i got my parts list: Oil pump and balance shaft module failure on 2.0L VW and Audi TDI engines
