1 - 7 of 7 Posts
Anyone ever found a fix for a leaking tandem fuel pump gasket? I mean the black gasket that is under the black (on my uk car) plastic cover that is on the outside of the pump. I have a very slight leek only now after removing the gasket and cleaning it and then applying a liquid gasket seal. You can't buy a replacement gasket apparently.
Between the tandem pump and cylinder head? I would give you the part number but I don't have the parts catalog for Seat. At least on the VWs, that seal is replaceable.
I can buy a gasket between cylinder head and the the fuel pump no problem. It's the gasket that sits under the plastic cover on the outside of the pump which has those torx headed bolts on it. Mine started leaking after i had the dreaded cam replacement job even though this part of the pump was not dismantled???
It seems odd that my dealer says you need to buy a whole new fuel pump if it leeks badly.
You don't say what year your Seat Ibiza tdi 130 sport is you could add this to your car spec then users wouldn't need to ask.
I can give you the part numbers and prices for all 6 parts listed for the vacuum pump on a 2005 1.4L/1,9L ASZ, ATD, AMF, BPX engines.
Seal - 038 109 293
Seal - 038 109 293 A
Seal - 038 145 215 - £5.43
Fuel and vacuum pump fuel pump - 038 145 209 E dropped on 01/03/2009 please use replacement 038 145 209 K
Socket head bolts with hexagon socket M8x25 2 off - N 090 378 2 dropped on 01/08/2010 please use replacement
Socket head bolt with polygon socket hd (combi) N 106 389 01
Hexagon socket head bolts (combi) M6x20 2 off - N 090 378 2
1.9 ASY engine.
Vacuum pump fuel pump - 038 145 101 B - £219.13
O-ring - 038 145 345 - £3.77
Hexagon bolt M8x35 - N 019 503 5 - £0.49
Double stud with hexagon drive M8x35 - N 908 048 01
Not all prices are shown. ;)
1 - 7 of 7 Posts
