1 - 6 of 6 Posts
Hi,
Not sure if this is the correct place to post - but its a 2007 SEAT Altea - so its a MkV!
I attempted the cambelt yesterday, and oh-my-god was it a killer. I followed the excellent guides on this site, and also the instructions in Elsawin. Here is a list of problems I encountered, and something to think of for those attempting it soon.
The first problem I found was no easy place to drain coolant (I was doing water pump as well). This car doesnt have a lower rad hose that you can access from below. The lower rad hose clip was in a place I just couldnt get to to release it. I dont have the special remote pliers - so next time I will!
I pulled the central hose near the oil filter. It spewed out most of the coolant - but I still had some gush out of the waterpump hole - something to think of if you attempt it yourself.
My 'Laser' crankshaft lock didnt fit very well. After about an hour of trial fits it would finally work as expected - I think it had some 'high-spots' on the casting - which made it really difficult to slide on and off of the crank sprocket.
My 'Laser' camshaft locking pin - OH MY GOD! I got it in, but it felt very tight. After rotating the engine, using the mirror etc I was confident the positioning was correct - the pin was just a really tight fit. The MAJOR problem was after I finished I couldnt not retrieve the pin! It took me about 1.5 hours to remove the pin. It was wedged solid. After many swear words I finally removed it using mole grips, by wiggling and prying. My fear was it breaking off in the cylinder head. I double checked all the timing using a drill bit of the correct diameter. I will check the torsion value using VCDS when done. The message here possibly buy better quality tools?
Finally the middle horizontal engine mount bolt is not accessible through a hole in the wing - as there isnt the hole in the wing on my car! Room is really restricted - I could not get a torque wrench on the bolt- there isnt enough space between the bolt head and the car body. I had to adapt, and use a 3/4 drive ratchet (with short 16mm socket), and use an extension bar to get the nm and extra turn. I hope it is ok!
So these are some things to watch out for if you are attempting it. The problem is you can't test fit the tools - as you have stripped it all down by the time you try to use them. Also this was my first modern cambelt, so I didnt know what to expect.
Overall very knackering. I still have the brakes to bleed, and the engine oil to change - then she is all done!
Thanks again for the advice on this site.
Cambelt change guide
Thanks for the post regarding issues when changing cambelt. Can anyone point me in the right direction for the guide for changing a cambelt for a 2007 Seat Altea TDI.
Cheers
1 - 6 of 6 Posts
