Hi I have a 2011 VW Jetta TDI and have recently swapped my rns-315 to a rns-510. It was all a plug and play operation. Why I did the switch was to get Video in Motion. So I had the Rns-510 unlocked with no can bus related type module. It works great with the DVD and all my factory modules are working properly. I wanted to go a step further and get Aux video into the Rns-510. So I ordered a multimedia interface VW RNS-E from T-era. Here is a link - http://www.t-era.co.uk/Pub/default.aspx?Page=ItemDetailEN&CatID=TE_43&ID=201538 I connected the module up, it connects to power, GND, and Can bus High, and Can bus low. It works..., but only as a reverse camera and does not have the video avaliable on the screen in the media menu like it supposed to.
Here's what my question is, How can I add in VCDS on the Can Bus Gateway the tvdb tuner? In the instructions it states bad grammer and all-
"ATTENTION!!! Interface cooperates with firmaware about numbers 522 and 102x. Its is required activation TV in setups CAN- Gateway Too:
Tiguan, Golf5, Touran, EOS, Jetta -- Address 19- Byte 3- Bit 4.
Touareg (08), T5 (08)- Address 19- Byte 4- Bit 4.
Press <Media> Button, next <TV> if DVD disc was restored, or <Media>, next <Video>, Then <TV> if music was restored."
But it wont work for me because my Can Bus Gateway only has a long code of 102200 no byte 3 avaliable. Can anyone help me out on programming this and getting it working I'm Lost. Here's my info. Thanks in advance for the help!
Friday,18,March,2011,19:11:03:60782
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 6N0
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 56 57 77
VIN: 3VWLL7AJ4BM053916
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Not registered 0011
Address 01: Engine (CJA) Labels: None
Part No SW: 03L 906 022 PB HW: 03L 906 019 DA
Component: R4 2,0L EDC G000AG 8216
Revision: 12H13--- Serial number:
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 74EDD3716E3D
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 054 J HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2601
Revision: 05351112 Serial number: 00001011040123
Coding: 0000020
VCID: 1D3BD6D5BD37
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: B14B400C492700FD8D1402E5921F0042A70000
VCID: 78F5E7417255
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0708
Revision: 00085000 Serial number: 0139448623
Coding: 030C0C
ASAM Dataset: EV_KESSY_PQ35GP A01010
ROD: EV_KESSY_PQ35GP_VW36.rod
VCID: 336F106D2BB3
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 Q HW: 5C0 820 047 Q
Component: J301 Klimaanlage 0103
Revision: 2000908S Serial number: 00000000191673
VCID: 2E590119C091
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 C HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0226
Revision: B2066001 Serial number: 03311349100139
Coding: 7A994B9A08A90B0008382000240884C50082502E6000000030A000000000
VCID: 2D5B0615CD97
Part No SW: 6R0 959 801 M HW: 6R0 959 801 M
Component: J386__TSG_FT 002 3463
Coding: 820000
Part No SW: 6R0 959 802 P HW: 6R0 959 802 P
Component: J387__TSG_BT 002 3463
Coding: 820000
Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Coding: 180000
Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Coding: 020000
Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3463
Coding: 800000
Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3463
Coding: 800000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTD08R70H
Coding: 00003935
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 346D13712EBD
Seat occupied recognition:
Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y10000023TJ0L
Coding: 303241
Driver's Airbag Crash Sensor:
Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME03312359ZZZJ
Passenger Side Airbag Crash Sensor:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4D4E4358ZZZ6
Driver's Rear Airbag Crash Sensor:
Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME6C28060EZZZ.
Passenger's Rear Airbag Crash Sensor:
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME0447000EZZZJ
Driver's Front Airbag Crash Sensor:
Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H01 ----
Serial number: 3556LSME7205740CZZZV
Passenger's Front Airbag Crash Sensor:
Component: F.Sens.Beif H01 ----
Serial number: 3566LSME6318740CZZZ-
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5C6 920 950 E HW: 5C6 920 950 E
Component: KOMBI H07 0406
Serial number: 00000000000000
Coding: 270A01
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 2C5D0B11F68D
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 0226
Coding: 100200
VCID: F0E55F619A25
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 5751 km
Time Indication: 0
Date: 2002.14.20
Time: 19:04:27
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0406
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD14D09BCF9
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0220
Revision: 00000000 Serial number: 10000072583003
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW36.rod
VCID: 2E590119C091
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668778370
Coding: 030000
VCID: 2757F43DEF6B
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 115
Mileage: 5751 km
Time Indication: 0
Date: 2002.14.20
Time: 19:04:54
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H10 1040
Revision: AB001001 Serial number: VWZ6Z7L4005105
Coding: 060104400000008100
Shop #: WSC 00000 000 00000
ASAM Dataset: ------------------------- ------
VCID: 234FE02D9B53
2 Faults Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 4
Reset counter: 115
Mileage: 5744 km
Time Indication: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 115
Mileage: 5744 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31631A65D1AF
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 234FE02D9B53
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 115
Mileage: 5744 km
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 115
Mileage: 5744 km
Time Indication: 0
Address 57: TV Tuner
Cannot be reached
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668824202
Coding: 0A00000000010100
Shop #: WSC 01383 790 50316
ASAM Dataset: UHVNA A01007
ROD: UHVNA_VW36.rod
VCID: 32611569D4A9
1 Fault Found:
0022 - Radio: No Communication
U1066 00 [000] - Short to Plus
Freeze Frame:
Fault Status: 00000000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
End ---------------------------------------------------------------------
Discussion Starter #2
If I can't get the TVDB tuner on this CAN bus gateway could I possibly purchase another Can bus gateway, let's say from a 2010 Jetta would that work? Would I srew my car over? Are they so vehicle specific? Anyone have experience?
